Brass nameplate samples
- miopicman
- Model of CNC Machine: Home built gantry type
'Flying Scotsman' and 'Billy Elwood' were designed and hand coded and took about a day each to code. On the other hand, 'REBUILT' was designed on Vcarve Pro and took about 5min to code. The last image was produced by Vcarve and shown to the client prior to milling.
- ssflyer
- Model of CNC Machine: ShopBot PRSAlpha 96x60
Re: Brass nameplate samples
Nice work! But, out of curiosity, why are you hand coding some when you have VCarve Pro?
Ron Sloan
- miopicman
The hand coded ones were done before I acquired Vcarve Pro. Somehow I don't think I'll be hand coding any more.ssflyer wrote:Nice work! But, out of curiosity, why are you hand coding some when you have VCarve Pro?
Cheers
Jim
Great brass plaques.
Hand coded huh? WOW.
VCarve is awesome, ain't it?
- miopicman
It sure is.Leo wrote:Great brass plaques.
The hand coding was a bit of a struggle but it's amazing what you can do when you have limited resources but plenty of time.
- Model of CNC Machine: Mill and router
Those are very nice.
I have been messing around with a few here. I have a couple of machine issue to sort out before I post any pictures of good ones.
There is some over cutting cause by backlash and an V carve step over which is too large.
I also have been experimenting with vibratory finishing.
The picture posted shows the defects.
I have a backlash issue to resolve.
I am curious what finishing did you do on them? What tool did you use?
Did you put a texture on the cuts or just a flat bottom.
Dave
Dave
- miopicman
Hi. I did not put any special finishing on the parts and the cutter was simply a 1.5mm flat bottomed end mill. Apart from removing some burrs, that is all that was necessary.Dfmiller wrote:Those are very nice.
Dave
I should be posting more stuff by now but my Kress router has had to go back to Germany for repair, so my milling at the moment has ceased. However, I've bought a air-coole spindle and inverter and am trying to get my head around programming the thing - has anybody had any experience of this?
