Hiii everybody
I'm new in this forum .. my name is David
my CNC machine (AXYZ) is operating now on old program ..& I hope to operate w/Vcarve because its simple & better ..
BUT I don't know how I will enter the router or drill bit parameters (diameter, depth,angle of the bit, ...& Rotation speed)
actually I know how to enter those in the nc file however my machine has 3 spindles and every spindle has a number, Now: my problem is to till the cnc machine that the programed tool inside the nc file is that tool which has the Number(e.g. No1 or No2)
As well as to till the machine that the selected tool has the exact parameters that I have actually.....
Thanks & Best Regards
David
Vcarve on AXYZ CNC machine
- Model of CNC Machine: AXYZ
Re: Vcarve on AXYZ CNC machine
thanks Tony... but till now no reply!!!!!
- Mark
- Vectric Staff
Hello David,
I think that we replied to your email, Tuesday morning.
We replied to an identical (exact wording) question that you have asked here
to someone named David (no surname given).
The question came from a different (hotmail) email account from the one that
you used to register on the forum.
If you used a hotmail email account to send us the question, please check this account
and the junk email folder for that account.
If you can confirm that this was your request, I can forward the reply to
to the email address that you used to register on the forum.
If this was not you, we do not appear to have received your email.
I hope that this helps.
Cheers,
Mark.
Cheers,
Mark.
Hello Mark,
sorry, I didn't note that I sent the Email from my second hotmail account.
BUT any way, I check the both daily, I didn't find any email received from you..
PLEASE kindly re-send it to any account
Thanks for attention & BEST REGARDS
David
David
- RoutnAbout
David,
It would probably be best if you sent them another email using the proper email address that way it won't go to their spam, And they'll get you taken care of with in no time.
They don't miss an opportunity to be helpful.
David
It sounds like all you need to do is the tool numbers coming out of V Carve is correct. Once you open the file in toolpath double check to see if the different tool are in different groups and that each group has the correct tool assigned.
