Thing is that no tricks are required here, as has already been said you can draw the lines that are required using the drawing tools supplied in the software, this does take some time & practice to learn & there is no quick way around that You don't need to spend hours on end at one time, a few spare minutes here & there will get you there over timesharkcutup wrote: ↑Mon May 23, 2022 4:49 amHappy to see that I am not the only one who tends to find workarounds or as some call it "cheating the software"!!!
But yeah as you continue to learn all the various options available you sometimes need just that little extra trick to produce exactly what you are looking for!!!!
Just my opinion/thoughts!!!
Sharkcutup
The advantage of taking the time to learn is that you can then reproduce just about any piece of artwork you want regardless of the quality or where the image came from
