Cutting issues lines left in material
rapps42@outlook.com
Model of CNC Machine: CWI CNC2 424
Post by rapps42@outlook.com »
Started this wood Sign At the The End I'm getting These Lines Not sure what is Happing The Machine is level
Re: Cutting issues lines left in material
Looks to me as though the v-bit you're using doesn't match what you've told the software it is. Either the angle, sharp/flat tip or both.
Tex_Lawrence
Model of CNC Machine: Shapeoko 3 XXL; V-Carve DT 10.514
Post by Tex_Lawrence »
I would guess that you've set a large stepover with a flat depth?
Where's the file? Post the file.
Crooked Wood Products - Custom Wood
Truth lies dormant in our future history ― Tex LXIX
Yep, large stepover with a flat depth is most likely. Didn't think of that as I never use flat depth with v-carve toolpaths and stepover isn't used in that case.
Post by adze_cnc »
The stepover for the flat might be a contributor but most of the letters don’t have a flat. So I would lean toward a mismatch between what the bit is and what tool database entry says that it is. I would expect that it is an engraving bit that has been entered as a v-bit.
Post by Rcnewcomb »
Can you upload your file (.CRV or .CRV3D) to the forum?
Here is a link describing how to upload your file. (How do I upload files or photos to the forum?)
If the file is too large to upload here you can use a file sharing site such as drive.google.com, onedrive.com, or dropbox.com. They all have free accounts available
  • Upload the file to the file sharing site
  • Make the link shareable
  • Share the link to the file here
Use the Windows Snipping tool for screen shots.
10 fingers in, 10 fingers out
another good day in the shop
