darken letters after carving
Wes
Model of CNC Machine: onefinity
Post by Wes »
Is there any other ways to darken letters other than painting? I use a lot of dark wood and the letters are hard to see.
SteveNelson46
Re: darken letters after carving
Post by SteveNelson46 »
Sometimes I use a magic marker (permanent) after a couple of coats of sanding sealer. Then the finish seals all.
Tailmaker
Post by Tailmaker »
If the letters are protruding (not v-carved), you can carefully flame them.
But if the wood is already dark, making the letters darker may not work well, anyway.
Puzzle, Finger Joint, Maze and Guilloche freeware at https://fabrikisto.com/tailmaker-software/
Pete Cyr
Post by Pete Cyr »
After carving ...a couple coats of lacquer or shellac...dry...apply liquid shoe polish..like kiwi with the foam applicator on the bottle....spear it in to the letters....wipe off immediately with paper towels.
You may Have to sand lightly and recoat with lacquer shellac.
You don't have to wait for the polish to dry to sand and lacquer
Charlie_l
Model of CNC Machine: CAMaster Stinger II
Post by Charlie_l »
Charcoal pencil dust brushed into text and then sealed.
Charlie
Aspire, CAMaster Stinger II
wb9tpg
Post by wb9tpg »
Laser them. I’ve lasered stuff that was V carved and also raised 3D letters. Comes out great
Gary Mitchell
Kentucky, USA
Wes
Post by Wes »
Thanks for the help
Post by Rcnewcomb »
Seal and use gel stain.
10 fingers in, 10 fingers out
another good day in the shop
