darken letters after carving
Is there any other ways to darken letters other than painting? I use a lot of dark wood and the letters are hard to see.
- SteveNelson46
Re: darken letters after carving
Sometimes I use a magic marker (permanent) after a couple of coats of sanding sealer. Then the finish seals all.
If the letters are protruding (not v-carved), you can carefully flame them.
But if the wood is already dark, making the letters darker may not work well, anyway.
- Model of CNC Machine: Camaster Stinger II
After carving ...a couple coats of lacquer or shellac...dry...apply liquid shoe polish..like kiwi with the foam applicator on the bottle....spear it in to the letters....wipe off immediately with paper towels.
You may Have to sand lightly and recoat with lacquer shellac.
You don't have to wait for the polish to dry to sand and lacquer
- Model of CNC Machine: CAMaster Stinger II
Charcoal pencil dust brushed into text and then sealed.
Charlie
Aspire, CAMaster Stinger II
- Model of CNC Machine: Shapeoko 3 XL
Laser them. I’ve lasered stuff that was V carved and also raised 3D letters. Comes out great
Gary Mitchell
Kentucky, USA
Kentucky, USA
Thanks for the help
Seal and use gel stain.
