Need input on text idea.
Is there any program out there, or some way to get curved text into Cut2D?
Re: Need input on text idea.
Maybe Corel?
Any CAD-program, exporting vectors?
Kees
Kees
- tamathumper
DeskEngrave is a free program that will convert curved text into G-code or DXF. I have not tried it with Cut2D.
http://www.deskam.com/deskengrave.html
This is from their website:
DeskEngrave is a basic True Type Font to Vector Converter that allows saving of G-Code or DXF files. It will convert a single line of text into the required toolpaths for engraving. It can create toolpaths aligned along an arc or straight line. It includes a TTF 'Stick Style' font - Stick40. It is being released to the CNC community free of charge. We hope you enjoy using DeskEngrave.
CNC: www.bitcarving.com; Hybrid 4x4, RockCliff, Mach3, Vectric Aspire 2 + Wildlife Scenes 1.
- metalworkz
You should be able to do it with most any CAD program, save as a .dxf and import into Cut2d. Many times I will volunteer to do it to help out, but my drive crashed recently and I don't currently have the ability.
- mboydraska
- Model of CNC Machine: 3 axis homebuilt
I use Deskengrave quite often, works great. Nice part, it is FREE
HAPPY CUTTING
Mike
Mike
I use DesignCad it can draw text along a curve, then export the drawing as .dxf, then import in Cut2D.
Inkscape might be able to do it for you. It's a freeware vector graphics program that can do text on a curve. It can also export as DXF. Not certain it will work for you but it's worth a look.
http://www.inkscape.org/index.php?lang=en
Just wanted to thank everyone on thier great ideas.
Was able to make a Christmas ornament for a relative who loved it.
Cut 2D won't allow for a preview in clear plastic, but the attached is what I made her.
- metalworkz
Cool ornament, I take it that the center part is suspended somehow. Thanks for sharing the final design with us.
- tamathumper
That's awesome!
What font did you end up using?
The True type font is called "Nightmare Before Christmas" from the Tim Burton anamation.
I tryed to attach the font to this post, but this forum does not allow ttf extensions.
- tamathumper
On some forums I have to .ZIP files before I can attach them.
Second times the charm, hope this zip works.
- Nightmare Before Christmas font.zip
- (11.51 KiB) Downloaded 201 times
- tamathumper
Thanks !
