job setup sheet
job setup sheet
Hi! is there a way to check the lenght of the toolpath for particular elements I'm cutting?
- Tex_Lawrence
- Model of CNC Machine: Shapeoko3XXL; JTech7W; V-CarvePro 11.554
Re: job setup sheet
Please define what you mean by "length of the toolpath."
Tex — Crooked Wood Products
Re: job setup sheet
how long are the cutting lines total in a particular element- I'm tring to figure out how to price what I cut.
Re: job setup sheet
Length as in distance can be seen by using the Span/Contour section of the Measure tool on the vectors used in the toolpath. It won't be 100% accurate to the toolpath length unless the cut is a profile toolpath on the line but should be good enough.
