Hello All! I recently purchased a Roland/Scott Machine Corp. SRM-20 commercial grade rotary engraving machine, I am starting a small business engraving plastic name tags, desk name plats and small signage. My machine came with a license for Cut2D Desktop. I also have a Genmitsu 3018-PROVer CNC router which came with a different software, so I know a little bit about CNC, however I am still learning Cut2D and I have a couple questions...
First, could anyone tell me how to set up a template that would allow me to run multiple different engraving jobs at the same time? I would like to be able to run up to 12 1x3 inch name tags at a time if possible. Thus far I have only been able to figure out how to run one tag at a time.
Second, how do I change font sizes to have more than one in the same job? Whenever I try to introduce an additional font size (usually smaller than the one I used first) everything converts to the smaller size.
Thank you all in advance!
Chris Blaase
Hagerstown IN USA
nv9z.blazingengraving@gmail.com
Cut2D Templates & Font Questions
Re: Cut2D Templates & Font Questions
Use multiple text boxes.Second, how do I change font sizes to have more than one in the same job? Whenever I try to introduce an additional font size (usually smaller than the one I used first) everything converts to the smaller size.
You can only have one font size in a text box, but you can have multiple text boxes, each with its own font size.
- Model of CNC Machine: Roland/Scott Machine Corp SRM-20
Thank you!
