We are delighted to announce the release of Cut2D Desktop & Pro V11.5!
Version 11.5 is a free upgrade to everyone who owns version 11.
If you’re entitled to a free upgrade, your version 11.5 software has been credited to your V&Co account automatically. To access your version 11.5 software, simply sign into your V&Co account using your registered email address and click on ‘DOWNLOAD your software’.
https://portal.vectric.com/
Alternatively, If you are not entitled to a free upgrade, you can purchase the upgrade to Cut2D Desktop V11.5 for $50 USD (excludes local taxes) or Cut2D Pro V11.5 for $110 USD (excludes local taxes).
To take a look at all of the new and enhanced features released in version 11.5 head over to our website here: https://www.vectric.com/upgrade
To see all of the new and enhanced features in action, click below to watch our short ‘what’s new’ videos:
Cut2D Desktop:
Cut2D Pro:
The release of version 11.5 includes lots of new and enhanced features including; freehand drawing, the ability to read image data from within SVG files, improvements to toolpath calculation speeds and much more.
The power of graphics hardware has increased dramatically in recent years. To make full use of this resource whenever it is available we have completely rebuilt the 3D rendering infrastructure across all the products in our v11.5 range. The result is the smoothest, highest detail, 3D View ever. Toolpath previews draw faster and with more clarity. The 3D material block can be viewed and manipulated dynamically while toolpath cutting is simulated, even in higher resolutions. Improved lighting and shading techniques in the 3D view provide consistent visual shape and depth cues whether working on single-sided or double-sided.
Any recent computer or hardware (less than five years old) will show a serious step-up in 3D performance when running v11.5. But our extensive testing shows that even older hardware will benefit. We have ensured that there is a robust, but slower, fall-back mechanism for outdated or incompatible graphics cards but it is essential in all cases that your graphics card drivers are up-to-date. Please visit your computer or graphics card manufacturer’s website for specific guidance on getting the latest drivers for your hardware.
• FREEHAND DRAWING TOOL
The freehand drawing tool is a new tool which closely mimics the flow of drawing with a physical pencil. Allowing you to create quick sketches and trace organic shapes much more easily. Within the form there are various options to control the drawing. the smoothness setting helps with the post smoothing of your vectors and the stabilisation setting helps to stabilise the cursor for a more accurate drawing. We have also included the ability to adjust the fading of your bitmap, saving you the hassle of having to exit the tool to make changes to the bitmap ready for tracing.
• SUPPORT READING SVG FILES THAT CONTAIN IMAGES
The software now has the ability to read image data within SVG files, ensuring that you get everything you need from the original file source.
• OPENING OF VECTRIC AND THIRD-PARTY VECTOR FILES
You are now able to open various file formats directly into the software, without the need to have the software open to begin with. Simply double click on the file, use CTRL + O or drag the file into the software. The file formats that can be opened directly include V3D, PVC, SKP and SVG with images. To ensure that your file type will always open with our software simply right click on the file and head over to the properties, here you can choose what program you wish to open this file type with, simply select your Vectric product and going forward windows will always open this filetype in our software.
• CUSTOM VARIABLES IN TOOL GEOMETRY IN THE TOOL DATABASE
Variables can be defined for the tool geometry in the tool database which can then be used in the tools’ naming format. The custom variables are accessible through the tool database ‘variables’ button for each tool geometry. It can then be used in the name format dialog either through using the handy drop-down menu or by typing the variable manually. This is particularly useful for distinguishing between tools with exact geometry, or adding further information to the tool that otherwise isn’t specified by our default tool database format. For example you could add variables that could pay reference to specifics such as the manufacturer, coating or whether your tool is an up-cut or a down-cut, giving you more options to organize your tool database.
• TOOLPATH CALCULATION SPEED IMPROVEMENTS
We’re making better use of the CPU cores in some parts of the pocket toolpath calculation, noticeably in toolpaths with lots of vectors. This results in speeds up to 2x faster in some cases.
• SIMULATION
When simulating a toolpath the camera can be twiddled around and zoomed in while the simulation is running and animating to allow focus onto areas of interest, ensuring for better visibility of your toolpath moves.
• SELECT DUPLICATES
The software now has the ability to identify and select duplicate groups and text entities in your file. Making it much easier to clean up duplications ready for use with other features in the software.
• MACHINE & TOOLPATH MENU
The machine menu and part of the toolpath menu has been made available without having any projects open to allow the tool database to be accessible, without having to open or create a new file.
Everyone running Cut2D Desktop or Pro V10+ on a computer with internet access will see an update notification in the top right-hand corner of its main window. Simply click on the notification link, log in to your V&Co account and checkout the latest V11.5 features.
If you run Cut2D Desktop or Pro on a computer without internet access, you can still access your account and download version 11.5 from any other internet enabled computer by visiting the V&Co site directly using your web browser.
Please note: V11.5 is a complete installation that will install alongside and independently of your existing software. Once you've installed V11.5, your previous version will still be available so make sure you are running the latest version by checking the text in the main window title bar (top-left). As soon as you are happy with your update, you can go ahead and uninstall your previous version.
Forgotten your V&Co password?
Just follow the forgotten password link under password entry box on the V&Co login page to reset it.
Forgotten your V&Co username?
This is usually the email address you registered with us when you first purchased your software. If you're still not sure, follow the link to email support and we can help you get back up and running.
Enjoy V11.5 from everyone at Vectric
Cut2D Pro & Desktop 11.5 OUT NOW!
- Vectric Staff
- Model of CNC Machine: xxx
