Roughing/detail passes from vector list?
I’m new to Vectric and loving the drawing s/w. I had been using Easel and they had a nice feature when you could create a roughing and detail gcodes from the same vector drawing. Does Vectric have a similar concept?
Re: Roughing/detail passes from vector list?
I'm doing inlays, so I cut out the "female" part out of the base wood with a 3mm end mill, then get the finer parts with a 1mm end mill. Here's an example:
The pocket toolpath in the Vectric products lets you specify multiple tools to do that.
