Quick question about Pocket Allowance
NewAtThis
Model of CNC Machine: Stepcraft M.1000
Post by NewAtThis »
Have I got this right?
I want to produce a box with a lip for a lid to fit on to it, similar to this (https://www.youtube.com/watch?v=jVA6f5C4Btw) video on YT. Should I use the Pocket Allowance to do this and, if so, is an offset of 0.02mm enough for the lid not being an interference fit?
Be wary of taking the advice of someone who thinks he knows what he's doing, and don't listen to me!
adze_cnc
Re: Quick question about Pocket Allowance
Post by adze_cnc »
It's a 26 minute video. Any particular time code we should look at?
It's also worth noting what the help file says about it:
Pocket Allowance
This option is used to leave material on the inside of the pocket for the Profile Pass to clean-up. This is often very useful for ensuring the cutter does not mark the edge surface of the pocket when roughing out.
FixitMike
Post by FixitMike »
Personally, I would use a clearance of at least .25mm per side. This may not be enough for some woods and machine setups.
NewAtThis
Post by NewAtThis »
adze_cnc wrote:
Sun Jul 31, 2022 9:07 pm
Point made. It's at 0:25 but I linked the video just to show the lip.
NewAtThis
Post by NewAtThis »
FixitMike wrote:
Sun Jul 31, 2022 10:44 pm
So, this would make the pocket in the lid 0.5mm larger than the lip it sits on.
That makes sense, thank you.
