Very new to Vectric software, but am working towards my first project (after a few tests!).
I'm trying to write text along a curve and, although I understand the principle, there's a shadow on the image after I preview the toolpaths, and I'm wondering what this indicates and if it will show in the cut.
Thank you
What will this mean..?
- Model of CNC Machine: Stepcraft M.1000
Be wary of taking the advice of someone who thinks he knows what he's doing, and don't listen to me!
- SteveNelson46
Re: What will this mean..?
I think that some of those "shadows" are where the bit can't reach. Try adding an appropriate sized clearance bit in the toolpath. Also, try setting your preview resolution a little higher. It's found under the toolpath menu /simulation quality).
Thanks, Steve. Increasing the preview resolution showed the cut much cleaner and without the 'shadows'.SteveNelson46 wrote: ↑Mon May 23, 2022 8:58 pmI think that some of those "shadows" are where the bit can't reach. Try adding an appropriate sized clearance bit in the toolpath. Also, try setting your preview resolution a little higher. It's found under the toolpath menu /simulation quality).
- Leo
Just shows to go yaSteveNelson46 wrote: ↑Mon May 23, 2022 8:58 pmAlso, try setting your preview resolution a little higher. It's found under the toolpath menu /simulation quality).
Learn something new every day. That is a HUGE thank you Steve.
- SteveNelson46
As usual with Vectric products there are at least 3 different ways to find a solution. I'm a fan of the tool Join/Close by Moving End Points
Mark Lindsay also has a good video on the topic.
