Break lines into multiple
jfournier
Model of CNC Machine: FoxAlien 4040-XE
Post by jfournier »
I've used Trace Bitmap, which worked great to generate vectors, but I need to split some of the generated lines into pieces to do my cuts.
Is there some way to split a single multi-line apart? I can visually break them up in node edit mode, but the software still treats both pieces as a single object, and I want to toolpath on just one part of the line...
FixitMike
Re: Break lines into multiple
Post by FixitMike »
jfournier wrote:
Fri Apr 22, 2022 1:25 pm
I'm assuming that by "multi-line trace" you are talking about the parallel vectors that result for each side of a line that is traced. They will be closed vectors, and have to be cut in two places to obtain a separate vector.
AboveCreations
Model of CNC Machine: i2r B22
Post by AboveCreations »
Is there some way to split a single multi-line apart? I can visually break them up in node edit mode, [bold]but the software still treats both pieces as a single object[/bold], and I want to toolpath on just one part of the line...
I am not sure what you mean by this. The software is what? Vcarve toolpath? What is both pieces? What do you consider "the software"?
The short answer to your question is no. I would need a lot more details of what you are trying to achieve to be able to help. Node edit is the best tool to editing nodes.
adze_cnc
Post by adze_cnc »
This suggests that both newly split lines are grouped together.
