Does VCarve Desktop v. 11.06 Post Processors for Shark II
I have noticed that in some of the applications, when I go to calculate my toolpath, that sometimes selection of post processors isn't available. Am I safe in assuming that the software automatically selects the processor for me for a particular carving? Like simply cutting out a profile?
Re: Does VCarve Desktop v. 11.06 Post Processors for Shark II
The same post processor setting is used for everything unless you have the Laser Module installed in which case that uses a different post processor that must be selected first.
Sounds like you may have missed the machine/post processor selection step if you're using V11 and have no post processors in the list when you come to save. You can re-run that from the Kickstarter Wizard on the Help menu.
