I have created a couple of files that I need to export to Illustrator for my graphics team. When I export them they do not seem to have the artboard size in them. Is there a setting that I need to change to make this happen?
Keith
illustrator export
Re: illustrator export
If you want a vector included that indicates the size of the material then you have to draw that vector yourself with all the export options other than PDF which gives you a job bounds option.
