Still working on my Crib Wars project. I want some areas on my crib board to be recessed lower than the main tracks. My problem is I have numerous lines/vectors running every which way, and I do not know how to select a group of vectors that would encompass the recessed area I would want. I have tried to select the individual vectors one at a time, but in doing so, without fail other vectors are selected being that they are joined to the one I wanted selected.Same problem if I try to select the area I want recessed by by drawing a box around it. Either some vectors are selected or some are not. I've included a PDF document showing what I have. I've added numbers to the areas I want recessed. The number one area is basically the entire area around the outside of the board.
Thanks in advance
Selcting vectors for pocket toolpaths
- TReischl
Re: Selcting vectors for pocket toolpaths
This is similar to doing text on text. It is an exercise in properly defining the vectors that enclose various pockets. Each pocket you intend to cut has to have its own closed vectors describing it. You may want to do a search for the text on text techniques. There have been several good threads about how to do it.
You cannot share a single line between adjacent pockets.
Currently the only way this could be machined is to use a Profile On the line strategy to machine all the vectors at a constant depth.
You will want to move your vectors to different layers to help organize and control how different sections are machined. In Cut2D go to Help/Video Tutorial Browser and search for Layer Guide - General Topics. This will help you to leverage Layers for your project.
This is also a case where the vectors needed for the various levels, etc. are best placed in their own layers. This is so that selecting the vectors is done en masse via the "Vector Selection" "Selector..." button rather than trying to manually dragging over every single one needed.
- Model of CNC Machine: Genmitsu CNC 3018-PRO
Thanks for all the helpful info! Talk about a quick response!
So; I could make a layer just for the recessed areas by moving all my lines to that layer and deleting the vectors I don't want or need. Than selecting the recessed areas and work from there?
- FixitMike
Also, if you use the Vector Selector feature in the toolpath window and by checking the right boxes, you can assign the vectors on a layer to a toolpath. Then, when you Recalculate All Toolpaths, all of those vectors will be calculated automatically without having to be separately selected.
Just thought I'd post my results after playing around with vectors. What I did do was remove all unnecessary vectors/lines from my project, just leaving the pockets that I wanted recessed. This worked. I did have problems joining some of the vectors so that a tool path could be calculated, but I eventually got them all joined and the tool path was successfully generated. Everything is a go except for the text. I have experimented with some and the results were not favorable. Trying to carve legible text 1/8 inch high may not be possible. My question is: Would a laser attachment be the answer?
To cut text that size I use 45 and 30 degree engraving bits using the single line fonts and a profile toolpath.
Thanks. I tried something along that line. I found a suitable single line font and using a V-bit, it worked. I had to drag the word (start) sideways to expand it. That seemed to give me something that was legible. Now I have to figure out how to highlight the word with paint without making a mess.
