Duplicate Mirror Object
ricklach
Model of CNC Machine: 1510 Workbee/5'x10 Colossus (home Built)
Post by ricklach »
I have created an object (2 sided) and placed registration holes in the object to align it when I flip it over. I need two of this object with the second being a mirror of the first. Should I create the tool path for the first object and save the two files (drawing and tool path), and then create the mirror object (can I use the same tool path - but updated) and save that set of files for the mirrored object. I am not certain what the work flow should be to create the two objects - one a mirror of the other. Any advice and assistance is solicited.
FixitMike
Re: Duplicate Mirror Object
Post by FixitMike »
Either way works. What I do is name the file(s) so it is obvious what they are for. For example: "VCarve .25 EM side 1, Part A"
