Image reversed in my design
- Model of CNC Machine: Genmitsu CNC 3018-PRO
Crib War project. Tried engraving my lines. Worked. Except for a slight problem. The image is reversed from left to right. What I did to accomplish that I don't know. This is the image in Cut2D. I generated the tool path for the lines and it came out reversed. I've read up on it and can't find anything to suggest what I may have done. I can't get it back to what it should look like. Not to worry. I had older saved an older image of what it should be; so all is good. Just would like to know what I did or didn't do to cause this!
Re: Image reversed in my design
