new to cnc
fishdogcnc
Model of CNC Machine: oliver 1013
new to cnc
Post by fishdogcnc »
ok guys im new to the cnc router game ive been a machinest for 20 yearsi run cncs everyday but the router is a little different i just bought a oliver intelicarve 1013 and im running the cut 2d desktop im haveing a couple issues
1 when i post the program it generates tool paths for tools that i have not selected like i want to use one tool for the whole program but adds finnish passes with other tools or generates a path with a bigger tool to rough out big areas
2 i posted a program like the avalon sign tutorial only i changed the avalon to my daughter name i set the work piece size to 12x15 inches the program ran fine but it is only like 1 inch by 1.5
has anyone else run into this or have any ideas where to find help
thanks in advance
jim
gkas
Re: new to cnc
Post by gkas »
1. Please use some punctuation. No punctuation makes it very hard to read.
2. Post your crv file here. It'll be much easier to diagnose that way. If it's too large to post, Put it on Google drive, Onedrive, etc. and post the link here. The cloud drives all have basic services for free.
fishdogcnc
Re: new to cnc
here's a link to the file that I'm having trouble with.
https://1drv.ms/u/s!As6F-SkJ7qNVplmmKwkHSN2S25UN
gkas
Re: new to cnc
Post by gkas »
fishdogcnc wrote:
Fri Sep 04, 2020 2:56 am
That links to a file named 'star.GEE'. What is it? I don't download unknown file types.
Re: new to cnc
Post by Rcnewcomb »
He posted the G code.
fishdogcnc,
we really need to see the .CRV file.
Code: Select all
G90 G00 X0.000 Y0.000 Z0.210
S18000 M3
G00 Z0.200
X1.446 Y1.990
G01 F15   Z-0.025
G01 F50 X5.706 Y1.854
X2.340 Y-0.760
X3.527 Y-4.854
X0.000 Y-2.460
X-3.527 Y-4.854
X-2.340 Y-0.760
X-5.706 Y1.854
X-1.446 Y1.990
X0.000 Y6.000
X1.446 Y1.990
G01 F15   Z-0.050
X2.340 Y-0.760
X3.527 Y-4.854
X0.000 Y-2.460
X-3.527 Y-4.854
X-2.340 Y-0.760
X-5.706 Y1.854
X-1.446 Y1.990
X0.000 Y6.000
X1.446 Y1.990
G01 F15   Z-0.075
X2.340 Y-0.760
X3.527 Y-4.854
X0.000 Y-2.460
X-3.527 Y-4.854
X-2.340 Y-0.760
X-5.706 Y1.854
X-1.446 Y1.990
X0.000 Y6.000
X1.446 Y1.990
G01 F15   Z-0.100
X2.340 Y-0.760
X3.527 Y-4.854
X0.000 Y-2.460
X-3.527 Y-4.854
X-2.340 Y-0.760
X-5.706 Y1.854
X-1.446 Y1.990
X0.000 Y6.000
X1.446 Y1.990
G01 F15   Z-0.125
X2.340 Y-0.760
X3.527 Y-4.854
X0.000 Y-2.460
X-3.527 Y-4.854
X-2.340 Y-0.760
X-5.706 Y1.854
X-1.446 Y1.990
X0.000 Y6.000
X1.446 Y1.990
G01 F15   Z-0.150
X2.340 Y-0.760
X3.527 Y-4.854
X0.000 Y-2.460
X-3.527 Y-4.854
X-2.340 Y-0.760
X-5.706 Y1.854
X-1.446 Y1.990
X0.000 Y6.000
X1.446 Y1.990
G01 F15   Z-0.175
X2.340 Y-0.760
X3.527 Y-4.854
X0.000 Y-2.460
X-3.527 Y-4.854
X-2.340 Y-0.760
X-5.706 Y1.854
X-1.446 Y1.990
X0.000 Y6.000
X1.446 Y1.990
G01 F15   Z-0.200
X2.340 Y-0.760
X3.527 Y-4.854
X0.000 Y-2.460
X-3.527 Y-4.854
X-2.340 Y-0.760
X-5.706 Y1.854
X-1.446 Y1.990
X0.000 Y6.000
X1.446 Y1.990
G00 Z0.200
G00 Z0.210
M5 M30
10 fingers in, 10 fingers out
another good day in the shop
fishdogcnc
Re: new to cnc
star.crv
(26 KiB) Downloaded 23 times
ok i think this is it.
this is a simple star im trying to profile. the gcode looks right and it runs but the size is wrong when i run it. on my machine it cuts a star 1.5 imches instead of 6 inches.
fishdogcnc
Re: new to cnc
star.crv
Re: new to cnc
Post by TReischl »
you have a mismatch between your machine units and what you are producing in the g code. Looks like your machine is set to run metric.
gkas
Re: new to cnc
Post by gkas »
fishdogcnc wrote:
Fri Sep 04, 2020 9:15 pm
Also, this will not cut a profile. The selection for the cut is 'on the line', so it will be smaller by the radius of the bit (1/2 the diameter). If you want it to be the same size as your drawing, use 'outside / right'.
Re: new to cnc
There are a lot of posts on the forum about inches/mm with these machines. The simplest thing to do to get it working is to save the code using the metric post processor rather than the imperial one. You can design in whatever units you like but the machine wants to see metric.
It seems to me that there was a change in the control software these machines run at some point as some owners insist they can run both units and other owners insist they are metric only.
