Very new to CNC.
Previously I was having issues with some of my dimensions being off so I decided to try to cut a piece specifically for verifying dimensions. However, I was unable to get it to even cut due to the following:
[ERROR] An error was detected while sending 'G1Z-0.500': (error: 22) Feed rate has not yet been set or is undefined. Streaming has been paused.
I went into the Gcode and added an F40.0 to the end of the first instance of 'G1Z-0.500, hoping it was recognize the feedrate.
No change.
Any suggestions?
Feed Rate Issues
Feed Rate Issues
- DimensionTest.crv
- (53.5 KiB) Downloaded 72 times
Re: Feed Rate Issues
Which post processor are you using? There was an issue with GRBL based ones (and their aliases) missing feed rates.
It was fixed in a later update for non-laser toolpaths so if you haven't updated to the latest version (10.505) that might be worth a go.
I've tried both BobCNC (inch)(*.gcode) and OpenBuilds GRBL (Inches)(*GCODE) and both gave me the same error.
Update: I was actually using version 10.503. I just updated to 10.506 and it worked! Thank you for the heads up!
