Is there a way of un-joining or exploding vectors that I have previously joined, and now want to edit?
Many thanks, as always!
Ken Alexander
Un-Joining Vectors
- Model of CNC Machine: Genmitsu CNC Router 3018-MX3
- highpockets
Re: Un-Joining Vectors
You can use the Cut option in Node Editing to selectively cut nodes apart or there's a Gadget called Explode Vectors that will cut the vector at each node.
Thanks John!
I see the Node Editing option you referred to and will give it a try. Unfortunately, Gadgets only appear to be a feature of Cut2D Pro and not Desktop, which is what I have. I think Node Editing should be more than adequate.
Thanks again,
Ken
Thanks again,
Ken
highpockets wrote: ↑Tue May 26, 2020 1:56 pmYou can use the Cut option in Node Editing to selectively cut nodes apart or there's a Gadget called Explode Vectors that will cut the vector at each node.
