Vcarve desktop pp Mach 4 inch , would like to change the file extension to .nc in the pp . I changed the name where it showes ".txt " to .nc but it still saves it with the .txt extension ?/
Ed
.text to .nc file extension
Re: .text to .nc file extension
Since you mentioned “.txt” and “.nc” I expect you didn’t change things in the “right” place.
POST_NAME is what I expect you changed. That is mostly informational. The real place to change is “FILE_EXTENSION”. See below.
Don’t forget to restart Cut2D after making the change.
Steven
Code: Select all
POST_NAME = "AXYZ A2MC (inch) (*.nc)"
FILE_EXTENSION = “nc"
Steven
- Model of CNC Machine: Fineline automation 50" x 50"
Thanks , that worked fine . I also would like to eliminate the command that sends the axis to x-0 y-0 at the beginning of a cut file . I always home (zero) my cnc before cutting and that move collides with my dust collection shield that i have put in place after homing .
Ed
Ed
That will be the XH YH line. There is a post processor editing guide on the Help menu that explains what each of the variables do.
