Double sided move
Double sided move
Does anyone know how to move a object that has items on both sides together. I have some double sided projects and have from time to time wanted to move/relocate and object that has detail on the other side and I've not figured out how to get both sides to move as a group. This comes up with nesting too. If I select objects to nest, the other side is not moved with the top side parts.
Re: Double sided move
You can't move them together. You need to use reference geometry or direct co-ordinates.
See this thread - viewtopic.php?f=2&t=31355
So I'm guessing then you can't do nesting with a double sided drawing.
That's perfect! Thanks! How did I miss that?
