Zero length span
Jan.vanderlinden
Model of CNC Machine: Xcarve
Zero length span
Post by Jan.vanderlinden »
What is a zero length span and how I correct it ?
Re: ZERO LENGTH SPAN
Click on the Fix Zero Length Spans button and it will fix it for you. Basically it's two nodes right on top of each other. If you want to fix it yourself you can go into node edit mode and delete one.
Jan.vanderlinden
Thank you Adrian.
I just saw that button and was going to post an edit.
Thank you for explaining what it is though.
