Incomplete installation
- Model of CNC Machine: Oozenest Ox 500 x 750/Openbuilds Minimil
Hi, I have just installed Cut2D on my laptop and the interface seems incomplete, I have tried twice with the same result. text and numbers are not present in the material set up dialog.....
Re: Incomplete installation
What version of Windows are you running? Looks like you have a custom theme setup as well. Did you change the fonts? Might be worth going back to standard to see if that corrects it.
I am on Windows 10, I will have a poke about 'under the bonnet' and see what I can find. Many thanks....
Also, what 3rd party anti virus program are you running, if any. I ask this because I was using AVG for years with no problem... when Vectric released v10 the AVG was flagging some files has potential threat. In fact, it quarantined one. I uninstalled that program and had no issues since... I now use Immunet.
Job sorted now thanks folks, it was a 'themes' issue in Windows 10...
