Page 1 of 1
Trouble setting tool pass depth
Posted: Sat Aug 24, 2019 12:36 pm
by helensdad
Hi, I am trying to set a pocket tool path to cut some numbers to a depth of 3 mm using a 1/8 ball nose endmill, but I cannot set the path depth, when I tryi in the tool edit box, I enter the number of passes, but they don't show on the main pocket screen. If I click 'calculate' I get the following... 'A formula used in one of the edit boxes is not valid'. I have attached tool set up and edit passes dialog boxes...[img]
[/img]
Re: Trouble setting tool pass depth
Posted: Sat Aug 24, 2019 12:49 pm
by ger21
For your cut depth, try using "3" instead of "3mm".
Posted: Sat Aug 24, 2019 1:15 pm
by helensdad
Cheers! That worked, many thanks. So simple a solution, I should have spotted that...
Posted: Sat Aug 24, 2019 2:08 pm
by scottp55
Good catch Gerry!
I looked at that for 10 minutes and my eyes skimmed right over that
Time for second cuppa for SURE
OR invest in one of these
https://www.youtube.com/watch?v=Z1Q_mXlTfcU
