PhotoCarve Software Info
boxerstoo
Model of CNC Machine: Black Diamoond
Post by boxerstoo »
Is there a way to override the automatic ratio size?
Xxray
Re: PhotoCarve Software Info
Post by Xxray »
Would be nice if X/Y could be unlinked, don't believe that is an option.
Doug
JimmyD
Model of CNC Machine: ShopBot PRSalpha, custom rotary indexer
Post by JimmyD »
Search for some software called halftoner. You can change pretty much anything, including cute ng lines, circular lines, wavy lines, dots and output as dxf.
Works great.
boxerstoo
Post by boxerstoo »
I think I have found a way to try and make the ratio for X/Y to unlink. Using PhotoCarve, you can't. However, I changed the ratio of the picture I wanted by first using Photoshop to the dimension I wanted, then loaded it into Photocarve.. Magic!!
I hate it when (THINGS) are smarter than me!
Xxray
Post by Xxray »
Sure, can always use another program to rescale, would be nice to do it on the fly within the program.
Doug
