Hi.
I dont know where to ask the question, but people here are using a lot of corian.
I need to mill some small 3D parts and I have a thin piece of corian, which need some backing material and I want to use plywood.
5min epoxy worked ok for 1 day for bonding the 2 materials, but when it was 100% harden after 24 hours, I could just open it like a book. Epoxy didnt bond with corian.
Can you recommend some kind of glue?
Glue for corian and plywood
Re: Glue for corian and plywood
Corian is glued with an adhesive made by DuPont. Google "Corian adhesive". You may be able to buy some from a local Corian installer.
Phil
Phil
- Xxray
Might want to try some good old titebond, I use it to glue plexiglass to mdf works great
Doug
- Model of CNC Machine: DIY
I used contact cement on one of my projects. It worked fine. I was using hardwood not plywood. I don't know if it's the best option, just what I had in the shop.
Jim
Jim
This is what I use when working with corian making nite lights Titebond Instant Bond Wood Adhesive http://www.rockler.com/titebond-instant ... ive-medium
Tony
Tony
Thanks.
This is a double post I couldnt delete. But as Jim_Nestor recommended, I had some gorilla glue and it worked.
I can now mill a little mould almost through the corian.
