1st Try at Firemans Shield
Bacwudz Kustumz
Model of CNC Machine: Shark HD
Post by Bacwudz Kustumz »
Here's my 1st try at the Firemans Shield... Still gotta work on my sanding but not to bad considering it was cut outta pine.
zeeway
Re: 1st Try at Firemans Shield
Post by zeeway »
That really looks good. Very clean cuts, which is tough in pine. Also good finishing job - is that shellac or some other clear sealer?
Angie
David Warkentin
Model of CNC Machine: Camaster Panther 4x8
Post by David Warkentin »
That does look good. Are the flat looking areas on the shield flat so you can vcarve names into them?
Bacwudz Kustumz
Thanks guys, Its just a spray on poly-stain finish that I rubbed with a greenie weenie to add some depth to the color. I havnt figured out how to carve in the flat areas of the shield yet but I'm working on it. I was actually gonna toss out a question on how to do that with vcarve or cut3D software.
COWBOY1296
Model of CNC Machine: SHOPBOT BUDDY PRS 32, 4 FT PWR STICK
Post by COWBOY1296 »
I am not sure if this addresses your question or not. Also i am using aspire 3.5 and cant remember the differance in the software.
There maybe better ways, but the way i did it was to draw a circle that looked as if it were centered in the flat areas. Then I created text on a curved line.
Bob Reda
Post by Bob Reda »
With aspire you can project toolpath onto 3d model. I don't know if that is available with v carve or cut 3d. With vcarve I would find the depth of the banner and start the cut at that depth. not sure on cut 3d
Bob
Bacwudz Kustumz
That was what I was going to try it says I can inport vectors from cut3d into vcarve but when I've tried it it doesnt work
PRO4824
Model of CNC Machine: AVID PRO4824
Post by PRO4824 »
That's the nicest pine I've ever seen!!
Isaiah 41-10
NewAtThis
Model of CNC Machine: Stepcraft M.1000
Post by NewAtThis »
Perhaps you could use the original design file, but set up the v-carvings on the design vectors used for those areas you want to carve, if you want to do it post-production? The problem with this option would be ensuring everything is aligned properly, so it might be better to incorporate v-carving the text with each badge you're going to cut, i.e. don't keep a stock of badges to v-carve at a later date.
Be wary of taking the advice of someone who thinks he knows what he's doing, and don't listen to me!
