Using Cut 3D and trying to add tabs to this model, attached, I can't figure out how to make the tabs bridge between the model and the material blank. They actually go inside the model and show up where they can't be in the finished part. Except for Tab 3, it's different, somehow, I don't know how.
Also with the tabs turned on, the final cut out doesn't work.
How do I fix this?
Tabs
- Model of CNC Machine: ShopBot PRSAlpha
Tabs
- SBplas1 Enclosure Top-5.5 Display_06.v3d
- (2.85 MiB) Downloaded 138 times
Re: Tabs
After watching a couple videos, I now understand, with tabs one shouldn't need a cut-out tool path.
HOWEVER, this points to another problem, neither the roughing nor the finishing cut through.
So how do I fix that?
Re: Tabs
Notice on the Add/Edit tabs screen it says:
Try entering “7” (or 6.35 if you want it to be the size of you roughing bit) next to the “Symmetrical” check-box. Then delete existing your tabs and re-add the tabs. This should come out better. It’s been many years since I’ve used Cut3D though.
If you note on screen "2. Material Size and Margins” for the option “Machining Margins around Model” you have “Symmetrical” checked with a margin of 0mm. The tab can’t be made from the edge of your model the edge of the machining boundary as they are one and the same (0mm offset) so the program does it’s best and your tabs "actually go inside the model and show up where they can't be in the finished part”.The tab will be added on the cut plane to bridge the model to the nearest machining boundary to the point you click,
Re: Tabs
I changed the roughing bit to 0.125", set the margin to 3.75mm, and the tabs just got longer on the inside of the part.
However, I experimented with placement of the tabs and while I never figure out where to click the part to get it to work, I did finally get 5 tabs that correctly link the outside of the part with the extra material.
Knowing that it has to have margin was key, thank you.
