Cut3D
sli21
Model of CNC Machine: QuickCNC 2.2kW Spindle 600/900
Cut3D
Post by sli21 »
hi all
just started doingsome 3d work on my cnc
i modelled up a round bowl in onshape as an stl file, loaded it into Cut3D, generated code and proceeded to machine it out.
the bowl is 420diam. my blank is round in shape
Can i machine the round bowl shape instead of the 420x420 square solid with the bowl enclosed? Does that make sense?
The machine obviously spends a lot of time cutting air where there is no material.
pictures attachd
thanks all
Scott
Re: Cut3D
In Step 2 (Material Size and Margins) try checking Use Model Silhouette.
sli21
Re: Cut3D
Post by sli21 »
Champion!! thank you very much
regards Scott
sli21
Re: Cut3D
Post by sli21 »
Adrian wrote:
Mon Feb 22, 2021 11:27 am
champion! thankyou
