Hi All - I have a strange issue. I draw up an item in cut2d pro, copy the item the paste it 4 times within the layout I created. I select all the items and go to Toolpaths. I set my Z safe to 5mm, select the tool I want to use, calculate without issue and then save using the imventables gcode post processor.
The first 2 items in the drawing cut perfectly - however when the router is meant to move onto the next item to cut it does not raise itself up to the safe z height. It simply cuts a line to the next item to cut. I recreated the drawing from scratch. This time when it got to the 3rd item the spindle did raise up and move but then started cutting in fresh air above the workpiece. I've also had it that the router plunges way too deep into the workpiece and starts cutting. Odd.
Any ideas - going crazy here. Thanks
Graeme
Cut2d cutting above workpiece
- gkas
Re: Cut2d cutting above workpiece
Please post your crv file. How do I upload files or photos to the forum? https://support.vectric.com/faq/vectric ... -the-forum
Hi, thanks for the reply - file attached.
- test file.crv
- (73 KiB) Downloaded 218 times
- gkas
I'm not sure if your bit Z=0 is getting set correctly. Your material thickness is specified as 25.19mm. but your cut depth is set to 10mm. You have tabs set for profile 3, but not profile 4. They look to be the same part. You can cut out all the parts by selecting all the profiles in a single toolpath. The cuts should not be above material, that would tend to suggest a setup error.
Hi, yes cut depth is set to 10 - I run the piece through a bandsaw afterwards to 10mm so the pieces fall out. I setup tabs on one to test. There were originally 4 of these in a row, all set to cut in one Toolpath - but this is where the issue comes in. It doesn't go to a safe Z after the 2nd piece had finished cutting...
You say you're using the Inventables post processor? I can't see one of that name in the standard list so presumably you've downloaded it from somewhere.
If you're cutting multiple copies of a shape with a single toolpath and it's not retracting between some shapes but is on others that has to be a post processor, control software or hardware problem. There's nothing you can do in the setup side of Cut2D that would cause that issue with a single toolpath.
Roger that - Sorry it's the openbuilds pp and cut in openbuilds software. I use a workbee cnc with arduino uno controller. Perhaps the standard grbl processor is better. Thanks for taking the time to reply to me!
Here is a case where the code output by the post processor would be to look at.
Hi - will post is asap
