Tapered tools
Tapered tools
Does cut 3d support tapered end mills or is this asking too much. I only see ball end mills of flat end mills on the menu. Thanks.
Re: Tapered tools
I guess the trial version is V1.0 and the newer version is 1.11. I have been told the newer version supports tapered tools.
- Model of CNC Machine: shark black diamond
Re: Tapered tools
If it does I can't find it on version 1.110
Re: Tapered tools
If you are trying to enter a tapered ball nose bit you would enter it as a Radiused Engraving bit being sure to enter the side angle and not included angle.
Tim
Tim
Re: Tapered tools
Each time I try that it goes in the data base but when I choose that tool for a job
it appears as a different degree angle. Seems like it defaults to the engraving bit angle.
I tried with customer support but they just keep asking for info that I already gave them
if they just look down the string of emails. Support= ask a question = get asked a question
back and the question's answer is in the prior email. Gave up on Nigel and support.
- JamesB
- Vectric Alumni
Re: Tapered tools
Janz - I have responded to your support topic. Please review and email me back if that does not help.
James
James
Re: Tapered tools
Ok I'm impressed now. Got the email from James and now things make sense. The x's 2 makes the angle right.
Haven't had a chance to try cutting with it yet. So bottom line is you can enter the tapered ball nose in the radiused engraveing.
All enters good there. The problem again was when choosing a tool (bit) for toolpath calc it shows the bit but the side
taper angle was X 2 and I didn't even think about x2 or /2 as I just saw it was not what I entered. James you get
an attaboy.
an attaboy.
- mtylerfl
Re: Tapered tools
Janz,tmerrill wrote:If you are trying to enter a tapered ball nose bit you would enter it as a Radiused Engraving bit being sure to enter the side angle and not included angle.
Tim
An attaboy goes to Tim also. He had your answer four days prior. (see above quote)
