Question of the day??-Milling Plastic (acrylic)
Forgive me because I am truly a beginer in the world of CNC. My project is to carve a 3d work out of a 1/2 to 1/4 inch of acrylic sheet. Can anyone direct me in the proper direction as far as tool bit, spendle speed and anything else knnowing. Thanks in advance.
- RoutnAbout
Re: Question of the day??-Milling Plastic (acrylic)
Here's a search using the words "feeds, speeds, acrylic"makavelly wrote:Forgive me because I am truly a beginer in the world of CNC. My project is to carve a 3d work out of a 1/2 to 1/4 inch of acrylic sheet. Can anyone direct me in the proper direction as far as tool bit, spendle speed and anything else knnowing. Thanks in advance.
Hope that helps... some great info and reading there
- Model of CNC Machine: Techno cnc
Make sure you get cast acrylic, the stuff with the adhesive paper protective layer. Extruded acrylic(has the thin plastic protective layer) has a lower melting temp and can quickly mess up your job!
Blog: http://www.fromaspiretobeyond.blogspot.com
Web: http://www.oxenhamdesign.com
- Xxray
You might be hard pressed to cut 3d anything out of 1/4, that is not much to work with. 1/2 is better, from my limited experience trying to carve 3d in plexiglass, the results are disappointing, as the tool polishes the surface and it is no longer transparent - Which kind of ruins the reason for using it in the first place. Of course, you may be using tinted, I don't know ... I did ok using the same general tools & settings that I use for wood.
Doug
- Model of CNC Machine: Seig KX1
I've been doing a lot of milling of styrene sheet and I have got excellent results using carbide cutters. They seem to cut cool and I get no problems with heating and melting of the styrene, and styrene has a habit of melting when you use HSS powered cutting tools.makavelly wrote:Forgive me because I am truly a beginer in the world of CNC. My project is to carve a 3d work out of a 1/2 to 1/4 inch of acrylic sheet. Can anyone direct me in the proper direction as far as tool bit, spendle speed and anything else knnowing. Thanks in advance.
As for feeds and speeds, I have constructed a test sampler which covers speeds from 2500 - 5000 rpm and feeds from 60mm/min - 500mm/min and there seems to be no obvious difference in cut quality with a 2mm cutter.
Jim.
