Personalized Gift
Gallery for samples created from Design and Make 3D Machinist or using Design & Make projects
Moderator: Todd Bailey
Teir
Personalized Gift
Post by Teir »
Hi all...
Been playing with different contrasts.
Leaving the 3d shiny and refinishing the outside
to a matte finish, really sets off the 3D model.
This style seems to get the best reviews.
Made on my rebuilt cnc shark...
Enjoy
Teir
js11110
Re: Personalized Gift
Post by js11110 »
Teir-
Great idea and very nice work!
Jason
The Official Vectric Cartographer
You are limited only by your imagination
glenn
Model of CNC Machine: home brew 40x20
Post by glenn »
Hi Teir,
Very good job, and you are right, the contrast makes your subject more distinct, and it really "snaps"!
Glad you got your cnc rebuilt. Is it more accurate now as well as quicker?
Thanks,Glenn
Teir
Post by Teir »
Glenn,
The particle board table had lots of flex before. I built a .75 tooling plate base with 2 captured rails and 2 round rails. X and Y runout are now in the .001's...i would say less than .010 on 24 inches. That part is working great.
I redesigned the lower gantry at the same time and made a bolted box 4x4 out of .5 and .75 aluminum flatbar. Again...it took out the flex of the lower gantry.
One problem came up when i put it back together. The small steppers they had on it now cannot drive it at 100%. I find myself programming in raster X so it takes small gantry moves, and let the Y and Z axis do all the long moves.
So...the short answer...i did not pick up much in the way of speed...but the quality is alot better with no table or lower gantry flex. I put drilled and tapped holes every 2 inches....and that works nice for setup...now i wished i had put them every one inch.
Teir
