this is the file that lead me to retrofit my older machine, so after new drivewrs,motors and the works
this is the first file i ran!!
jim
3d for local yacht club
Moderator: Todd Bailey
- Thkoutsidthebox
yacht
Very very nice James. The carved part is excellent but the flat plane its raised from is seemingly flawless. Was there much finishing on the background & did you cut the edge on he machine also? What were the details of the cut, bit etc? Great 3D work! I'm copying you
Alchemy CNC ~ Where Technology meets Imagination.
- Model of CNC Machine: CAMaster 508 ATC
the file is stretched to 12" tall 20" wide the boat is .625 deep. 1/8" taper bit at 10% stepover, the wood is yellow heart and i did cut the profile out with vcarve! the ptofile was then run with an ogee (standard router) light brush sanding with a 180 pad and shot with one coat of laquer. will post photo when i can install (down with flu)
thanks for your compliments
jim
jim
