EPS outline?
Gallery for samples created from Design and Make 3D Machinist or using Design & Make projects
Moderator: Todd Bailey
Phil
EPS outline?
Post by Phil »
In another post AngelicDiablo showed pictures of a beautiful scallop shell box.
He wrote: "My first shot at a VA3D box. Really simple to do. Just pick a design that would be suitable for a lid and use the .eps outline on the VA3D site to make the box."
I haven't found information regarding the EPS outline How is this done? Where can I get information about this option?
AngelicDiablo
Model of CNC Machine: Shopbot BT48 Standard
Post by AngelicDiablo »
Select the image on the vectorart3d site where you see the 3 style options and you'll see the selection for the outline. :twisted: -AD
Buckle up... it makes it harder for the aliens to suck you out of your car! :-)
Phil
Post by Phil »
That helps but I'm still not getting all the way. In VA3D I can't find an option to work with an EPS file.
Thanks in advance.
mrBOND
Post by mrBOND »
My guess is that he made the lid in VA3D from the 3D model, then used the outline-eps to get the shape of the box (in another program) Vcarve maybe? But I've been wrong before...
AngelicDiablo
Correct Mr Bond. Outline EPS was opened VCP4 and worked from there. -AD :twisted:
