VA3D Scallop Shell Box
Moderator: Todd Bailey
- AngelicDiablo
- Model of CNC Machine: Shopbot BT48 Standard
My first shot at a VA3D box. Really simple to do. Just pick a design that would be suitable for a lid and use the .eps outline on the VA3D site to make the box. The only hard part for me was making it a hinged box. A little trial and error but I was able to get it to work. Enjoy. -AD
Buckle up... it makes it harder for the aliens to suck you out of your car!
Beautiful box, very nice work! Would you mind sharing a few pointers on how to do one? I've done some 3D models but I haven't messed with the eps outlines much yet. I'm not sure what process I need to use to make a box. Thinking ahead to Christmas...some jewelery/trinket boxes would make pretty nice gifts.
- AngelicDiablo
IYWD, well you would carve out the lid like any carving and cut it out. Make sure the wood is thick enough for the carving. The box I made is roughly 6X5X3". The lid was 3/4 stock. The bottom is 6/4. But I just glued 2-3/4" pieces to make it that thick. I used the outline and offset the vector inwards .375". Once you have the bottom anchored down, I used a .25 EM to hog out the material that will be the interior of the box. After that is done I used the same EM to cut the box out. There are several ways to anchor the lid to the box. The hard part is matching the top to the bottom so they line up correctly. Take a look at the Rockler or Woodcraft site for the different type of hinges they have. -AD
AD,
Thanks so much for the info! I'll have to start looking for some suitable pieces of wood to try it with. I'm assuming for the bottom part of the box you do the inside offset .375 and do a pocket toolpath for making the interior of the box, then do a profile toolpath to cut the outside. Is that correct? When you cut the outside profile do you set it for no offset or an outside offset?
Thanks again for the helpful information.
IYWD
IYWD
- AngelicDiablo
