Hi,
I did some complex vectorized drawing and when I tried to create shape from vectors, it not show up all forms.
I can say that "Create shape from vectors" command ignore a few vectors. Vectors was created one by one, are close vectors and
is created a group with all of them under the same layer.
Anybody can help me ?
Thank you,
Mihai
vector missing or ignored ! ?
Re: vector missing or ignored ! ?
Very hard to say without seeing the file. If it's legal to do so could you attach the CRV3D file from Aspire? If not some screenshots would help.
OK,
I did two screenshots.
The missing vectors are in the "halo" model (no on the face or hair).
Thank you,
Mihai
Thank you,
Mihai
make sure you do not have duplicate vector at the outer ring area, you might be picking up a duplicate, or sharing the same curvature line. You might choose the check for duplicate vectors, or choose your complete design and move it to another layer and make it not visible and see what you have left, then look at the new layer by itself and see what you actually have.
Roy
Roy
Thank you , I will !
Mihai
Mihai
I know you said the vectors were all closed shapes, that that would be the most probable cause. Realize that grouping vectors does not make them closed shapes.
Have you ungrouped all vectors and selected the missing ones one at a time, then press the J key to open the Join Vectors tool to see if they are really closed? It may be worth doing a second check.
Tim
Tim
Since the shape on the left works and the ones on the top and right don't I would copy the left one to the other locations and see if that corrects the problem. A mirror copy would take care of the right side.
Russ
Russ
CAMaster MC3050-R w/steppers and Mach3, Aspire 8.02 D&C Series 1A &1B - Wildlife Scenes
Hi,
Thanks to you guys, I solve my problem.
I will pay more attention in future on closing vectors.
Pictures are relevant,
Thank you,
Mihai
Thank you,
Mihai
