I'd like to vcarve a clock dial but have no success in placing the 12 numbers in 30 degrees steps correct.
I drew a circle and copied 12 lines around the center to have the correct angle but with the ' wrap text around a curve' tool I have no success.
Any ideas out there ?
Richard
How to create a template for a clock dial
- Model of CNC Machine: ShopBot PRS Alpha
Re: How to create a template for a clock dial
Richard,
Make your first line the exact distance from the center to where you want your numbers placed. Then do your copy rotate. Next choose your font and create your numbers one at a time. Lastly, select your numbers and drag them to the end of each line and they will snap and stay at that position. Now you can delete all the lines and your numbers are in place.
I hope this is what you were after. If not, give us a little more information and we'll take another crack at it.
Bill
Bill
Bill,
thanks for that tip
Great result
Richard
thanks for that tip
Great result
Richard
- Model of CNC Machine: Romaxx WD1
I really like your clock face. Would you mind sharing the file?
Jim
Jim
No problem , Jim , here it is
Richard
Richard
- ClockDial.zip
- (664.48 KiB) Downloaded 435 times
Thanks for the info and data.
Tic Toc tic toc
Tic Toc tic toc
For those who like roman numerals
The font can be found here : http://www.iconian.com/a.html called achilles
Richard
Richard
- AchillesRoman.crv
- (844 KiB) Downloaded 245 times
