Swan in pink swirled Corian
The Gallery is for posting photographs and images of work machined using Cut2D
IBBruin
Model of CNC Machine: Homegrown
Post by IBBruin »
The swan was downloaded from Vectrics 3D models and tool path generated in V3 Machinist. After importing the toolpath into cut2D I did the layout geometry and depth of cut. I decided not to polish this to a glossy shine. I used 220 grit paper on an orbital sander with a very light finishing pass which gave it the look and soft feel of a bar of soap. I've seen some unbelievable things produced by others that I can't hold a candle to but this is probably the finest piece of art I've created with my home made cnc router.
This will be my first post on this forum so I hope the picture shows up.
tmerrill
Model of CNC Machine: ShopBot
Re: Swan in pink swirled Corian
Post by tmerrill »
I think it looks great and you should be pleased.
Welcome to the forum and I hope to see more of your projects in the future.
Tim
IBBruin
Post by IBBruin »
I gave it away to a friend. Now the wife wants one. Is there no end? lol
Post by Rcnewcomb »
It looks much better than my first attempt at a swan in marble. You should be very proud.
jimwill2
Model of CNC Machine: CaMaster Stinger w/recoil, FTC
Post by jimwill2 »
Very nice work!
Jim Williams
ailmik
Model of CNC Machine: Joe's Hybrid
Post by ailmik »
Top job IBBruin. Question thou, how do you normally go about polishing corian?
Regards
Kim
IBBruin
Post by IBBruin »
I chuck up a 4 inch cotton wheel in my drill press, set the spindle rpm to max and use some green polishing compound I get at Harbor Freight. It's time consuming but you can even get the rough side of corian polished pretty well.
ailmik
Post by ailmik »
Excellent. Thanks for the tip.
Cheers
GaryR6
Post by GaryR6 »
Nice and thanks for the tip on polishing..... I just got some cut offs I'll give a try.
zeeway
Post by zeeway »
Beautiful work.
Angie
IBBruin
Post by IBBruin »
Thank you all for the kind words.
Rcnewcomb, I'd be proud if my first attempt looked as good as yours.
