Swan in pink swirled Corian
The swan was downloaded from Vectrics 3D models and tool path generated in V3 Machinist. After importing the toolpath into cut2D I did the layout geometry and depth of cut. I decided not to polish this to a glossy shine. I used 220 grit paper on an orbital sander with a very light finishing pass which gave it the look and soft feel of a bar of soap. I've seen some unbelievable things produced by others that I can't hold a candle to but this is probably the finest piece of art I've created with my home made cnc router.
This will be my first post on this forum so I hope the picture shows up.
Re: Swan in pink swirled Corian
I think it looks great and you should be pleased.
Welcome to the forum and I hope to see more of your projects in the future.
Tim
Tim
I gave it away to a friend. Now the wife wants one. Is there no end? lol
It looks much better than my first attempt at a swan in marble. You should be very proud.
- Model of CNC Machine: Joe's Hybrid
Top job IBBruin. Question thou, how do you normally go about polishing corian?
Regards
Kim
Regards
Kim
I chuck up a 4 inch cotton wheel in my drill press, set the spindle rpm to max and use some green polishing compound I get at Harbor Freight. It's time consuming but you can even get the rough side of corian polished pretty well.
Excellent. Thanks for the tip.
Cheers
Cheers
Nice and thanks for the tip on polishing..... I just got some cut offs I'll give a try.
- zeeway
Beautiful work.
Angie
Angie
Thank you all for the kind words.
Rcnewcomb, I'd be proud if my first attempt looked as good as yours.
