Routed Jewelry Box
SPalm
Routed Jewelry Box
Post by SPalm »
The cherry drawers and tray are 1 inch thick, the top and bottom are 1/2 inch. The basic carcass is held together with five 1/4 inch dowels. Two are used as hinge pins for the drawers, and the other three are hidden inside the back. I made the back plate out of separate pieces to keep the assembly easier – dowels are so unforgiving. The drawers press against this back plate which allowed me to slightly sand the back of the drawers until they closed with just the front gap that I wanted. I used brass washers to separate the drawers. It all worked out quite nicely in the end.
I am posting the design file. Feel free to use or modify it if you want. I stripped out any special tabs and clean-up routing to keep it simple. You may want to modify the back plate concept to match your woodworking skills. I used a wooden hinge, but a lift off top would be nice also. The drawers work better with a finger grab and I used glue on walnut knobs for this, but there are lots of options.
Jbox.crv
(435.5 KiB) Downloaded 3637 times
jasond
Model of CNC Machine: Homemade cnc
Re: Routed Jewelry Box
Post by jasond »
Very nice! Thanks for sharing
jam1962
Model of CNC Machine: Self built 36x25x7
Post by jam1962 »
Looks like the begining stages of a "Project of the Month".. :?: . I like it.
Thank you for sharing the file and idea, this is now on the list of things to get around to.
Jay Morris...
calgrdnr
Model of CNC Machine: ShopBot prt with 4g upgrade
Post by calgrdnr »
Looking very Good and thanks for sharing Kent
Bob Reda
Post by Bob Reda »
Thanks for the generosity!
Bob
zeeway
Post by zeeway »
Steve,
Thank you again for another innovative design. I will add this to my "Spalm box" collection.
Angie
SPalm
Post by SPalm »
Hey People,
The CRV file above is from Version 6.5, so I guess if you don't have that version you can not load it. Here are the DXF exports from my two main working layers.
The 'Large' layer contains the profile, pocket, and drill for the top, the top tray, and the bottom. The top is routed with just the profile. The top tray is routed with the profile and the pocket. The bottom is routed with the profile and the 5 drills. I drilled all the way through the bottom for ease of dowel insertion and then also used this as a manual drill template for drilling the bottom of the top tray with a drill press.
The small trays are routed, pocketed and drilled. They are routed two at a time for grain matching.
Just a thought. If you want a lift off lid, you could route a reverse pocket on the top's underside. This would create a indexing protrusion on the bottom of the top to keep it in place. Also the flat top is a perfect canvas for some VCarving.
JboxLarge.dxf
(37.54 KiB) Downloaded 2002 times
JboxSmall.dxf
(34 KiB) Downloaded 1738 times
davewierenga
Model of CNC Machine: Stinger1
Post by davewierenga »
Nice jewelry box, thanks for sharing.
Dave :D
LoneTreeCreations
Model of CNC Machine: Blackfoot v4.1 4x4 home built router
Post by LoneTreeCreations »
Thank you Steve, I'm excited about trying this one for my wife.
Pete
Lone Tree Creations
galerdude
Model of CNC Machine: Joe's 4x4 Hybrid R&P Evolution
Post by galerdude »
Nice share!
Gale
Regards,
Gale
kzeyus
Post by kzeyus »
Very Nice!
Thank you!
Ken Zey
Rogers, AR
http://www.CedarSlabSigns.com
http://www.lookoutmercantile.com
Shopbot PRS Alpha 72x144
ssflyer
Post by ssflyer »
I love the drawers! Tanks for sharing, Steve!
Ron Sloan
jsantos
Post by jsantos »
Really nice! Thanks for sharing.
PeteC
Model of CNC Machine: Probotix FireBall Comet
Post by PeteC »
Thank You for sharing. I think I'll try it. :D Let you know how it comes out. :wink:
Bigfoot
glenn
Model of CNC Machine: home brew 40x20
Post by glenn »
Thanks!
