Clock, Pocket cut
Clock, Pocket cut
Is is possible to do a pocket cut but preserve the height of the numbers. I would like to cut down 1/8 in the surface but leave the numbers untouched. I only have Cut2D. Can this be done with VCarvePro.
- clock2.crv
- Wood 10 x10 x .5. Dia of clock 9in.
- (21 KiB) Downloaded 145 times
Re: Clock, Pocket cut
Select all the vectors and create a pocket toolpath with a 1/8" cut depth. That will take away all the material inside the circle but leave the numbers standing. You'll need a pretty small bit to get round the numbers though.
I wasn't selecting all vectors. So simple. works great. thank you
