V-Carve Wizard suggestio for enhancement
Option to eliminate background on preview
I would like the option to not have the blue background saved with the preview, i.e. just save the material and drawing in the preview file.
- Wemme
Heres one That I would like to see.
Time is very important here as we need to compete with cheap imports.
Say if you need to pocket and area.
first I want to use a big cutter to do the bulk of the cutting (problem is, it won't fit in all the places such as around text etc)
second I want to use a small cutter to do the bits the large cutter can't but not to do all the bit that have already been done with the large cutter (i.e save time)
Is this something that others would find of use?
Cheers
Bart
Cheers
Bart
Wemme Reply
Tony et al,
At the risk of sounding greedy.....
Yes, it would be helpful to be able to hog out bulk material with a big bit, and then hit the details with a .125.
- Perry
- Model of CNC Machine: Modified Shopbot PRT96
Regarding "hogging out", here is a work around that I have used. In VCW, create an island around the items yo wish to spare from the large bit, and create an offset inside the perimeter of you projects border. Using the 2D tooling, "pocket" these areas with the larger bit.
Now the remaining islands, cut as you would normally.
Like I said, a "work around" that seems to work for me.
Hogging out
To a limited degree we can do "hogging out" with flat clearance V-Carving. Select a small ballnose bit for V-carving and a .5 or .75 inch endmill for the flat clearance option.
I we could select a small end mill for the V-carve part of the toolpath we could square up the edges of the cut and perhaps have the ability to do inlay as well.
I did the attached Buffalo with a .125" ball nose bit at.5" deep and the flat clearance with a .5" end mill.
- (40.33 KiB) Downloaded 427 times
Remembering settings
I would like Vcarve Wizard to remember the last setting of:
View/Use Shaded Background
and
Animate Preview
or at the very least allow me to default those features to "OFF"
and
Animate Preview
I've been playing with different ways to take a V-carve file and reverse the carving so that the resulting cut would produce an image that stands out from the background rather than cut into the surface. It occured to me that if there was a feature in V-Carve Wizard that would reverse the Z coordinates, that is change the negative Z values to positive values, the effect I refer to could be achieved. This feature could be incorporated into the "flat area clearance" toolpath strategy to achieve a carving with a recessed background and a raised image. I think this would be a really cool feature. What do the Wizards think?
Reverse v-carving
Phil,
That capability is already there. The way to "raise" is to draw another shape around what you want to reverse v-carve.
Check out this link for a brief tutorial:
http://www.222artisans.com/vcarve.html
Reverse V-carving
we can cut raised images like the raised V on the http://www.222artisans.com/vcarve.html web site but that is not the same as the reverse V-carving I am refering to. If we were to reverse the teardrop image at the top of the 222artisans page there would be a taper along the length of the image. The raised carving we can do now would leave the teardrop flat across the top in the same way that the V on the 222artisans web page is.
- Paco
Babbling about something to hold part in place while cutting 'em out...
Which one would you like?
... or are you looking for something different?
Hey good tutorial Rcnewcomb!
- (52.21 KiB) Downloaded 361 times
- (49.97 KiB) Downloaded 373 times
- (48.68 KiB) Downloaded 364 times
