"You've Captured My Heart" - Vectric Project - FREE to all
crash5050
Re: "You've Captured My Heart" - Vectric Project - FREE to all
Post by crash5050 »
Something is still not right. It has got to be the way I am holding my mouth. I can run thru the roughing pass and all looks well, I then put in the 1/8th inch ball nose re-generate the gcode at the Zed that I have set, and it only finishes the right hand side of the parts, the left hand sides it just passes over, it acts like it thinks the parts are larger than they really are. More investigation is in order.
David
Post by mtylerfl »
crash5050 wrote:Something is still not right. It has got to be the way I am holding my mouth. I can run thru the roughing pass and all looks well, I then put in the 1/8th inch ball nose re-generate the gcode at the Zed that I have set, and it only finishes the right hand side of the parts, the left hand sides it just passes over, it acts like it thinks the parts are larger than they really are. More investigation is in order.
David
Hi David,
Question for you...
Are you allowing your machine to proceed all the way through the project? It seems it is not too uncommon for a toolpath to begin machining a part, then move on to another before completion, then return to the previous one to finish it up from where it left off. If you permit the machine to keep running, then all toolpaths should be completed just fine. Please let me know if that is the case with you, or if you are aborting before the machine has a chance to finish.
Thank you in advance for letting me know. I look forward to your feedback.
sawmiller
Model of CNC Machine: joe's rack and pinion hybrid
Post by sawmiller »
had some snow here today, with the attendant power outages that come with them if your back in the sticks.
rearanged so it would cut from one longer board, and generated individual roughing and finishing passes to try to avoid power outages... made it, about 3 hours of cutting at 150ipm on the joes rack and pinion
thanks micheal
In the heart of Tn
Post by mtylerfl »
sawmiller wrote:had some snow here today, with the attendant power outages that come with them if your back in the sticks.
thanks micheal
Fantastic! Great strategy to parcel up the project to work between possible power outages alright! I'll have to remember that - seems like whenever grey clouds gather, we get some "power flicker" in the mid-afternoons. (I often try to schedule machining for early AM or later PM to dodge the power issues.)
myshadowboxes
Model of CNC Machine: Camaster Stinger
Post by myshadowboxes »
Love the project and as I have not picked up anything for my wife and daughter yet, I thought this would be a great gift. Downloaded it and tried to add it to Aspire.... Wham hit me like a ton of bricks. I have not been able to purchase the 3.o upgrade. Is there any way to save this file into Aspire 2.5?
Anthony
mtylerfl wrote:
zeeway wrote:Hey Michael,
Any chance of you posting a Cut 3D file version of the puffy heart? With that, I believe I can make a version of the rest with VCarvePro.
Angie
Hi Angie,
Thank you for your question. I'll check with the folks at Vectric next week to see if that's something that's feasible. However, I'm pretty sure this particular project would not come out quite like it's intended if done with VCarvePro.
sawmiller
Post by sawmiller »
i have both 2.5 and 3... i can save as a stl and import back into 2.5, looks the same, no vcarving, and you would have to make the confining circle for where you wanted to 3d carve... no problem, just dont know why it's not available in 2.5 also, and if it's permissable to post it in 2.5... sorry
if it's ok, i'll convert it. already cut it for the wife :)
dan
In the heart of Tn
Sargmaster
Post by Sargmaster »
that would be cool if I could get it dome by Valentines day
sawmiller wrote:i have both 2.5 and 3... i can save as a stl and import back into 2.5, looks the same, no vcarving, and you would have to make the confining circle for where you wanted to 3d carve... no problem, just dont know why it's not available in 2.5 also, and if it's permissable to post it in 2.5... sorry
dan
sawmiller
Post by sawmiller »
micheal ?
In the heart of Tn
BrianM
Post by BrianM »
dan
Hi Dan,
As they say on many forums .. If theres no pictures it didn't happen! Please post some pictures, I'm sure it is extremely motivating for Michael and also encourages Vectric to invest in future projects. These projects require time (and hence money) to produce to these standards and we need to be sure that the effort is justified and appreciated.
We have no problem with this as long as it is for a Vectric product, we would have problems with people posting the files for use in other sytems as Vectric have invested the money in producing this project for our customers. The project is designed to be used very easily from start to finish and our brief to Michael was to use Aspire 3.0 as this is the current version. We have no problem with someone converting it for Aspire 2.5, but I hope people understand that it is natural that as we create these projects we will be doing them in the latest versions of the software.
Brian
Post by mtylerfl »
Hi Guys!
I was trying to limit my "surf time" today so I could actually get caught up a little with some work. :)
Sorry, I missed the whole discussion when posted, but sure glad Brian chimed in in my absence (thanks, Brian!). Looks like he explained everything very well!
EDIT: Yes! Photos are always fun to look at, and encouraging too! (Not just for me, but for everyone!)
sawmiller
Post by sawmiller »
can't get it under 1 meg upload limit .. arrgh
here's the picture anyways
In the heart of Tn
sawmiller
Post by sawmiller »
aye Brian, using the latest version is only smart, 3.0 is way easier.
unfortunately i can't get it under 1.76 meg zipped, even not having toolpaths :roll:
i'm probably doing something wrong
In the heart of Tn
BrianM
Post by BrianM »
sawmiller wrote:aye Brian, using the latest version is only smart, 3.0 is way easier.
Hi,
If you email it to support we will upload it and post a link.
Brian
Mark
Model of CNC Machine: CNC Shark, ShopBot, Roland PNC3000
Post by Mark »
sawmiller (Dan) has provided a version of this project suitable for
Aspire version 2.5
It is available from here:
http://www.vectric.eu/projects/aspire/ycmh2.5.zip
Dan has asked me to remind anyone wishing to use this version of the project,
to ensure that they alter the feeds and speeds to values suitable for the
machine on which it is cut.
And that if in doubt, an air cut is advisable before making an actual cut.
Many thanks to Dan for providing this.
Gerry Perrault
Post by Gerry Perrault »
Thank you Dan
For the 2.5 version of ''ycmh''. I have downloaded it ,the only problem is how do you deselect the component to be able to do profile on each element and to be able to v-carve the lettering.
AS for my self the writing would be in french:''TU AS CAPTURE MON COEUR''
it could also be written in spanish : TU HAS ATRAPADO ME CORAZON
in Italian: HAI RAPITO IL MIO CUORE
With these 4 version of the phrase that will cover most of the Vector community.
and we could do it ourself for the carving.
Can you supply me with the information.Thank you again.Gerry
I rather be the leader,than the follower
