Fire up the dragon.
The Gallery is for posting photographs and images of work machined using Cut2D
Fire up the dragon.
Postby dustybugger » Mon Aug 09, 2010 1:01 am
Having some fun with a multicolored LED strip and first try at pocketing plastic. About 6x6x1/4, used 1/8 and 1/16 endmills at about 9000rpm at 20 ipm. Only problem was getting off the paper on some very old plexiglass. Surprised how well it came out with no finishing.
John V
dustybugger
Re: Fire up the dragon.
Postby MikeUSNRet » Mon Aug 09, 2010 2:44 am
how deep did you cut?
looks nice
STGC(SW/AW) M. Wenman USN Ret.
1982 - 2005
MikeUSNRet
Postby dustybugger » Mon Aug 09, 2010 6:46 pm
This was done at .03 deep. Seems to be enough to get a good image.
John V
dustybugger
Postby MikeUSNRet » Tue Aug 10, 2010 6:00 am
Thanks for the reply...yes, it does look as if .03 is enough. I had heard that some people just barely scratch the surface and it looks great. I tried one last month, although not illuminated, but think I cut too deep.
Mike
1982 - 2005
MikeUSNRet
Postby deadgoodcharlie » Wed Nov 16, 2011 12:23 am
Where can you get the led light from?Thanks.
deadgoodcharlie
Postby oxenham1 » Wed Nov 16, 2011 5:16 am
Looks awesome. Try warming the protective paper to get it off easy. I usually run a heat gun over it until the paper feels slightly warm to the touch. Some of our smaller pieces of acrylic are over 13 years old, and this always works well.
Blog: http://www.fromaspiretobeyond.blogspot.com
Web: http://www.oxenhamdesign.com
oxenham1
Model of CNC Machine: Techno cnc
Postby dustybugger » Wed Nov 16, 2011 5:14 pm
I used a nice little multicolored base from Decor&After,llc. The units ran about $15.00 with its own power supply, as cheap as I could build them. Also thanks for the tip on the paper removal, I will give that a try.
John V
dustybugger
Postby mancman4 » Fri Feb 03, 2012 2:18 am
What a fantastic job.
Is the dxf available for the dragon anywhere...?
Jason
mancman4
Postby dustybugger » Fri Feb 03, 2012 1:34 pm
Jason, For the image try www.vectorink.com under the fantasy group. Lot of great images there.
John V
dustybugger
Postby mancman4 » Sat Feb 04, 2012 2:49 am
Thanks for the link John.
Much appreciated.
Jason
mancman4
Return to Cut2D - Gallery
Users browsing this forum: rlp17820 and 0 guests
