Sorry if this has been answered before but I looked for previous posts and could not find an answer.
I am modeling in Rhino and when I save a file as an .stl and open it in Cut3D, All of the smooth surfaces are jagged. I have tried many options to fix this but the right one. I'm assuming this is more of a Rhino problem but any ideas on how to fix this? Thanks Mike
Rhino and Cut3d......Problems with .stl files?????
Re: Rhino and Cut3d......Problems with .stl files?????
Here is a quick answer that may help, but hopefully someone with more Rhino experience than me will contribute.
It is a Rhino issue, Cut3D is simply importing what the model is. So you need to focus on how to setup Rhino to create and export a more detailed model.
An .stl file is saved with a surface mesh of triangles. Rhino should have the ability to increase the number of triangles, which will improve surface quality at a cost of increased file size. Rhino also has a smoothing feature if I remember corrrectly, which may help.
Recommend you take a look in the Rhino Help file under .stl and see if something pops out. I have Rhino on my computer, but just found out I can't open the help file...
Tim
Edit: I just found these, they may be a good starting point and get you moving in the right direction:
http://wiki.mcneel.com/rhino/stlinfo
http://wiki.mcneel.com/rhino/meshfaq
Tim
Thanks. That's where I had my problem. I knew it has to do with the way it is meshed but I didn't know how to manipulate the settings. Thanks again!!!
Hi Vectric people,
I'm a big rhino user and was hoping that you are considering a direct rhino file import?
I am very impressed with your software and community and would like to becme a vectric customer and make use of cut3d for some of my projects.
Thanks, Greg
Thanks, Greg
Hello Greg,bradyg wrote:Hi Vectric people,
I am very impressed with your software and community and would like to become a vectric customer and make use of cut3d for some of my projects.
Thanks, Greg
Thanks for the positive feedback but afraid we are unlikely to develop a direct Rhino import option.
The industry standard 3D STL mesh format essentially ensures that the file import process will work regardless of the version of Rhino being used as the modelling engine.
Tony
Hi Tony,Tony Mac wrote:Hello Greg,bradyg wrote:Hi Vectric people,
Thanks, Greg
Tony
Fair enough, guess I'm just being lazy! Do you directly import Solid Works models? I'll give the slicer a go and see how it holds up on a test model.
Thanks for the reply, Greg
