Vacuum Failure on an otherwise lovely project
Gallery for samples created from Design and Make 3D Machinist or using Design & Make projects
Moderator: Todd Bailey
Post by Rcnewcomb »
It was going along so nicely. The first pass was (almost) done with a 1/2" ballnose. It was 90% complete when the vacuum let go due to too many holes in the pine.
If it had worked then it would have been:
Material: Pine 47.5x9.25x0.75
Pass 1: 1/2" ballnose at 10% stepover @ 6ips, 72 minutes
Pass 2: 1/8" ballnose at 8% stepover @ 6ips, 85 minutes - dog & pheasants only
It was going so nicely...
When vacuum doesn't suck it really sucks.
Oops!
Oops!
DOH!
DOH!
moto633
Re: Vacuum Failure on an otherwise lovely project
Post by moto633 »
Take it over to that miter saw in the background and trim it off! :D
Phil
Post by Phil »
Been there. I keep a few of my bloopers on hand to remind me of things that went wrong.
gravirozo
Post by gravirozo »
hello
randall, i think for a display in your shop, it still pretty good... at least the hours are not wasted time... of course with some fix as others suggested...
thanks
viktor
Post by Rcnewcomb »
I'll hang it in the shop as a reminder to fill in worm/nail holes in wood before putting something on the vacuum table.
tmerrill
Model of CNC Machine: ShopBot
Post by tmerrill »
Randall,
I normally don't like pine, but that is some pretty wood!
I didn't realize those holes would be enough for you to loose vacuum.
Tim
buck4
Post by buck4 »
Randall,
Do you always cut at 6ips, that seems pretty fast. 30ft/min, wow!! Your spindle most be at 40 thou plus rpm's. Sorry I got to believe, that the vacuum did let go, by cutting too much too fast.
Buck
Post by Rcnewcomb »
Yes, that is my standard feed rate, though the Z movement means I rarely get up to that speed. Usually the vacuum has no problem. At 10% stepover I'm only removing 0.05" per pass with the 1/2" ballnose.
gravirozo
Post by gravirozo »
hello
most possible, the board cupped up... as i can see there was removed about 60-70 percent of the board thickness...
and the vac could hold down on the beginning because the board was "straight" and by removed material some stress raised in the wood... and the vacum that was enough on the beginning, already was not sufficient... some thicker board able to pull nail out...
thanks
viktor
kilrabit
Post by kilrabit »
Randal,
What are you using for the Z feed rate, and are you using the CV mode? I made a few of the mountain sheep mantels 6 feet and 8 feet long, I used the dish to help eliminate the destressing of the wood. I used 2 inch quarter sawn white oak, and left a depth of .750 in the deepest place of the stock, it still moved about 1/8 of an inch in two directions when I unclamped it, and I used 5 sets of linear clamps to hold it down.
Post by Rcnewcomb »
6 ips as well
I'm not running Mach, I'm using the Shopbot control software with default ramp rates. I plan of doing some tweeking but we have had consistently good results with these settings for the past few years.
That would have worked much better. I love carving quarter sawn white oak, and leaving 0.75 would have improved stability.
I think Viktor is correct that the combination of holes in the board and the cupping caused by removing so much material were the root causes of the vacuum failure.
But now I know for sure....
Dropout
Post by Dropout »
We do a fair amount of work with pine and find that the easiest thing to do is screw it to a piece of melamine before we put it on the vacumm table.
Dublinman
Post by Dublinman »
I couldnt endure listening to a vac for the amount of time a 3D carving would take. I would use screw down clamps or t track.
Alchemy CNC ~ Where Technology meets Imagination.
Post by Rcnewcomb »
Well, we can't hear the vacuum above the noise of the router.
Some day we'll have a spindle....
backyard_cnc
Model of CNC Machine: SHOPBOT, LIGHTMACHINES MILL, AJAXCNC-KNE
Post by backyard_cnc »
I sometimes reduce the chance of movement by pinning stock to the table with 23gauge pins I shoot in with an air nailer. 23 gauge pins hold well yet are so thin that if you machine threw one it shouldn,t damage the router bit. The stock is easily pryed off the table.
Gerald
